I am using the AXBB-E controller and a friend of mine made a 21 piece cut program for me from Aspire cut 2D. He uses MAch 3 and so do I. For clarification I have ran multiple single part cut programs with this controller on mach 3 with no issues.
When I loaded the g code file it only displayed the first part to be cut and that was it. The rest of it was no where to be found. This program is nested on a 48" x 32" sheet of plywood so it is quite a few parts. I also swapped to my older USB motion controller unit and plugged it in and got the same result. I put in a ticket request to Artsoft/ Mach 3, and Trevor responded with my "my motion controller plugin files were broken and not reading the G code." So they haven't been much help. The attached screen shot shows the single part that I see when I load the file. To me their response doesnt make sense because I can load other programs on both controllers and cut the program. Does anyone have any clue as to what is going on?
Thank you
