Mach3 not reading cretain g-code lines
Postby Filipe » Thu May 25, 2023 6:06 pm
Hi there,
I'm trying to run a simple g-code, but when I load it into mach3, it omits some of the lines. For example:
g1 x10 y10 z5 f100
g12 I5
In the code above, mach3 only loads the first line. Any command I try to use to make a circle or an arc, is not shown.
Does somebody have any clue or had this problem?
Thanks!
Filipe
Re: Mach3 not reading cretain g-code lines
Postby ger21 » Thu May 25, 2023 7:31 pm
Open the two lines in a text editor, put your cursor at the end of the second line, and hit enter, then save.
Or, save your code as:
g1 x10 y10 z5 f100
g12 I5
Postby Filipe » Thu May 25, 2023 7:57 pm
Thank you! It worked fine!
Filipe
Return to Mach3/4 Discussions
