AXBB-E Mach3 Plugin Settings Encoder Problem
Postby teratsuba » Fri Aug 13, 2021 5:02 pm
I want to thread with Mach3 turning.
I found that G76 can be used by setting the index pulse and AB encoder.
I tried to set the encoder from the plugin settings, but I couldn't select port 3.
(The encoder signal is connected to pin 12 and pin 13 of port 3.)
UCCNC was able to set it correctly.
What should I do with this?
Please tell me.
teratsuba
Re: AXBB-E Mach3 Plugin Settings Encoder Problem
Postby cncdrive » Sun Aug 15, 2021 3:08 am
Why you can't set port 3.? It is not selectable in the plugin? Or what is the problem?
Postby teratsuba » Sun Aug 15, 2021 3:47 am
thank you for your reply.
The pull-down port list has 0, 1 and 2,
but 3 is not in the list.
teratsuba
Postby jt.hiltunen » Tue Aug 17, 2021 9:47 am
i have a same problem my new AXBB-E controller. encoder signal is connected to port#2 pin 4inp and 5inp + index pin3. index flashing mach3 diagnostic screen and Rpm gauge work well but threading G76 not work.
jt.hiltunen
Postby cncdrive » Tue Aug 17, 2021 6:53 pm
OK, we will check this problem, it has to be an error in the plugin then.
Postby vrsf.concept » Sat Jun 03, 2023 4:11 pm
Hello! I have exactly the same problem with my new AXBB-E controller. encoder signal is connected to port#2 pin 4inp and 5inp + index pin3.
Index flashing mach3 diagnostic screen and Rpm gauge approximately twice the real Rpm and threading G76 not work.
A don't know how to solve it.
Could you help me?
Frédéric
vrsf.concept
Postby cncdrive » Wed Jun 07, 2023 1:48 am
Try to exchange encoder hannel A input with channel B in the settings, because if the threading cycle is not starting is probably because the encoder is counting to the wrong direction. Chaneging the channels changes the counting direction.
Also in Mach3 with low speeds, If I recall below about 200 RPM the threading won't work.
Return to Mach3/4 Discussions
