I bougth Mach4 and try to get it run with the UC300 ETH(+UB1). After installing the UC300 Plugin and doing the basic setup, the machine seems to run pretty well.
After a restart of Mach4, the Input/Output Pin mapping in the control configuration were lost. I have to setup the device and input/output name on every start of Mach4. Mach4 does not save these values.
I am a bit confused, becaus any other values get saved. Only these UC300 specifc values cause problems.
This thread on Machsupport describes the same problem. However no solution is found. The suggestion is, to contact the cncdrive support.
https://www.machsupport.com/forum/index.php?topic=41747.0
Unfortunately I have not found any information here. To use the UC300ETH with Mach4 seems to be not very common.
Is the problem known and is there a solution? Maybe someone is using Mach4 successfully with CNCDrive hardware?
Thanks in advance.
Heiko
