Problem with axxb-e and Mach3
Postby DanielSun » Sun Jul 21, 2019 9:55 pm
my Axxb-e or mach3 or mach3 Plugin has a little Problem.
The Problem ist the direction look's to work the CNC works and changes the direction.
But the Problem is ports and pins, when i Change there direction low or high nothing changes (it should change the direction configuration).
I have an gantry and have to change the direction of the Y Slave Axis.
I have the problem since the first day but I used steppers and I changed the pinning to change the direction, but now I changed to JMC servos and can't change the wirering.
Can somebody help me?
Best wishes Daniel
DanielSun
Re: Problem with axxb-e and Mach3
Postby cncdrive » Mon Jul 22, 2019 1:41 am
Post your xml profile file and tell us which axis is not changing the direction for you so we will check it out.
Postby DanielSun » Mon Jul 22, 2019 6:18 pm
Hi here my XML
CNC BIG.7z
(7.67 KiB) Downloaded 252 times
DanielSun
Postby DanielSun » Mon Jul 22, 2019 7:19 pm
All axis have this Problem
DanielSun
Postby cncdrive » Fri Jul 26, 2019 9:20 am
We could reproduce the problem and working on the solution.
Postby DanielSun » Sat Jul 27, 2019 8:59 am
Thank you for the information. Please give me a update how I can fix it.
DanielSun
Postby Tweakie.CNC » Wed Jul 31, 2019 11:44 am
Unfortunately strange and perhaps unexpected things happen with Mach3 when the "Ivan Todosijevic" (Pirate License) is used.
Tweakie.CNC
Return to Mach3/4 Discussions
