Problem output with uc300eth plugin
Postby foxfly » Fri Mar 15, 2019 10:32 am
hello output signals mach4 do not work with uc300eth help
foxfly
Re: Problem output with uc300eth plugin
Postby cncdrive » Fri Mar 15, 2019 10:36 am
A little bit more informations would be required to give you help.
Like how did you decide that they do not work?
And which outputs, on what ports on what pins for what signals?
Postby foxfly » Fri Mar 15, 2019 10:56 am
I configured output pins as in mach3 but in diagnostics no spindle light, flood etc .. does not work I also have an analog spindle control. in mach3 everything works perfectly
foxfly
Postby cncdrive » Fri Mar 15, 2019 11:31 am
It works for others.
Which outputs? Which pins which port?
Postby ger21 » Fri Mar 15, 2019 11:49 am
foxfly wrote:I configured output pins as in mach3 but in diagnostics no spindle light, flood etc .. does not work I also have an analog spindle control. in mach3 everything works perfectly
Mach4 is very different than Mach3. You probably do not have it set up correctly.
Postby foxfly » Fri Mar 15, 2019 12:17 pm
thanks i solved the problem, is there a new plugin for mach4 and uc300eth?
foxfly
Return to Mach3/4 Discussions
