Thanks.
Spindle direction and control is not clear for me. I have two questions here :
1) How to choose CW or CCW tapping ?
Do we need to start the spindle with M3 or M4 before calling the NotifyPlugins(10200) function ? Then the plugin reverse direction at Zend ?
2) Is it possible to change spindle speed for retracts ? For retracts, it is common to choose a faster spindle speed to save time, 4 times faster is a common value.
Here is a Rigid Tapping macro i wrote with R parameter for multipass tapping. Let me know if i'm right. To test this macro i disabled the plugin code, because my spindle encoder is not yet ready to test that on the machine. Then it is not fully tested yet.
If someone can test it i would be interested to know the results.
There is some code inside to avoid running the macro if another one was running before. This is a protection i use inside my macros to limit crashes if another macro did not end correctly. This is especially useful during testing to check that there is no runaway macros.
- Code: Select all
Option Explicit
Const RunningMacroLED = 1242 ' Modify according to screenset
Sub Main()
'Rigid Tapping Macro - CNCDrive - Olivier ADLER 2025
'P parameter = Z end
'Q parameter = pitch (positive number)
'P & Q parameters must be specified for each successive tapping
'R parameter = pass depth for multipass tapping (must be a positive number)
'R parameter is permanent until mach3 restart (does not need to be specified for each succesive tapping)
'Use R0 to set back single pass tapping
'//////// Variables
Dim Multipass, MultipassDepth, Zend, Z_Axis_Pos, ZDepth, OtherMacroRunning
'//////// Pre processing
Message "" 'Clear message line
If GetUserLED(RunningMacroLED) Then 'If User LED 1242 is on, another macro is runing, take measures
If Question ("Another macro is running, enter 1 to force execution") = 0 Then
If Question ("Enter 1 to clear the macro runnning LED") = 1 Then
SetUserLED(RunningMacroLED,0) 'Clear the macro runnning indicator LED
End If
Message "Another macro is running, exiting !"
Exit Sub
End If
OtherMacroRunning = 1
End If
If param2() <= 0 Then 'if Q parameter is not a positive value then exit macro
MsgBox ("Parameter Q must be a positive value, exiting macro")
Exit Sub
End If
If param1() = -1 Then 'P parameter is probably not defined, ask and exit macro (-1 value is the default for unset parameters)
If Question ("Enter 1 to confirm P : Z end = -1, or 0 to exit macro") = 0 Then
Exit Sub
End If
End If
Z_Axis_Pos = GetOEMDRO(186)
If param1() > (Z_Axis_Pos - param2()) Then 'Zend is higher than Z axis position or thread with less than one turn, exit macro
MsgBox ("Zend is higher than Z axis position or thread with less than one turn, exit macro")
Exit Sub
End If
If param3() > 0 Then 'If R parameter is defined then enable multipass mode
Multipass = 1
MultipassDepth = param3()
Message "Multipass Tapping"
End If
SetUserLED(RunningMacroLED,1) 'Enable the macro runnning indicator LED
'//////// Processing
If Multipass = 0 Then
SetUserDRO(1200, Param1()) 'P parameter = Z end
SetUserDRO(1201, Param2()) 'Q parameter = pitch
Sleep (250) 'Could be necessary
NotifyPlugins(10200) 'Load parameter
SetUserDRO(1202, 0) 'Start Rigid tapping
While(GetUserDRO(1202) = 0) 'Wait for finish rigid tapping
Sleep(50)
NotifyPlugins(10201)
Wend
Else 'Multipass Tapping
Zend = Param1() 'P parameter = Z end
ZDepth = Z_Axis_Pos - MultipassDepth
If ZDepth < Zend Then
ZDepth = Zend
End If
'SetUserDRO(1201, Param2()) 'Q parameter = pitch
Do
SetUserDRO(1200, ZDepth) 'P parameter = pitch
Sleep(50)
Wend
Sleep(250)
'MsgBox ("ZDepth= " & ZDepth)
If ZDepth <= (Zend + 0.0001) Then
Exit Do
End If
ZDepth = ZDepth - MultipassDepth
ZDepth = Zend
End If
Loop While(ZDepth >= Zend)
End If
Sleep (250)
MsgBox ("P =" & param1() & " Q =" & param2() & " R =" & param3() & " Multipass =" & Multipass)
'//////// Post Processing
If OtherMacroRunning = 0 Then
SetUserLED(RunningMacroLED,0) 'Disable the macro runnning indicator LED
Else
If Question ("Another macro was running, enter 1 to clear the macro runnning LED") = 1 Then
End If
End If
End Sub 'End Main Sub
