SurfaceProbe (Bed of Nails)
Discuss the creation and usage of Wizards
Postby Vmax549 » Mon Jan 15, 2018 3:36 am
Here is a wizard that will write teh code for surface probing in Z.
There is a glitch with teh save points files writing. Unless you use teh {SET} button on teh probe config screen to change teh save to location it will always write to teh Example_Gcodes folder (;-).
The Field on teh probe config screen will reflect teh saved file name from teh Wizard BUT it will not save to the proper location. It just saves to teh Gcode folder.
Just UNZIP teh files to your Macro folder. You can then call it up from teh MDI line M20926.
(;-)TP
SurfaceProbev1.zip
(23.74 KiB) Downloaded 26 times
Vmax549
Return to Conversational Wizards
