Conversational Wizards
Discuss the creation and usage of Wizards
Re: Conversational Wizards
Postby dezsoe » Fri Jan 05, 2018 8:23 pm
Thank you, now it works.
(Some hours ago I read the new posts on this thread and got inspired. :) Some pieces of the puzzle got connected in my head and I started to build a "framework", something like the Mach wizards. I don't know where will I get with it, but now I have some ideas to try. I don't promise anything, but I will keep that... :))
Postby Dan911 » Fri Jan 05, 2018 9:04 pm
That looks great Terry, do you plan on sharing? If so going to delete what I just started working on in my VS project folder...LOL
I sure it will work better once the canned cycles are fixed in UCCNC.
Postby andrewbishop66 » Fri Jan 05, 2018 10:16 pm
Hi Terry
All I can say is I hate looking at candy 8-) when or how can we taste
They have the look of some very useful tools would be so nice to have thread milling back
Thanks Andrew
andrewbishop66
Postby bennyhines70 » Fri Jan 05, 2018 10:46 pm
Have to agree with Andrew. Terry ,These wizards look great. When do you think you will be able to share these ?
bennyhines70
Postby Dan911 » Fri Jan 05, 2018 11:12 pm
Vmax549 wrote:Well I had hoped for UCCNC to address Wizards by providing a Folder to load them to and and a sub to hold teh graphics files and to be able to call them by name. Otherwise it can get messy to work with them. Then a Menu to be able to call them up.
I can do a menu for Plugin styles but teh macro styles can only be called by teh Mcode name ( M9982) but you have to be able to remember what teh Mcode for teh wizard you want to run (;-).
SO I am open to ideas on how to handle them in UCCNC.
(;-) TP
Why not create a plugin menu like I posted but instead of calling to a class like I did call macro?
Postby Dan911 » Fri Jan 05, 2018 11:27 pm
If you would like post what label names you want, and in the plugin configure I'll make a editable link for button to macro. I did this for AC's probe but he didn't want it. :shock:
Postby dezsoe » Fri Jan 05, 2018 11:51 pm
Start the macro files with a fixed pattern, e. g. "// ##This is my macro for anything". Scan the macro folder for .txt files which have the first line starting with "// ##", add the rest of this line as a name and the macro number to a list if the pattern is found. Your menu is ready to use in runtime. Also, you can store the results in a combobox on the standard screen and have a button to start the selected macro/wizard. (It's about 1AM here, so I go to sleep now. If you'd like, I make it tomorrow.)
Postby alex_s » Sat Jan 06, 2018 8:29 pm
probe dimension of stock
Faceing
Pocket ( rectangular / circular) which could also be used for slotting
Contour ( rectangular / circular )
Hole pattern ( circular / rectangular ) with starting points center or edge defined, and pecking
Threading ( in- / outside )
but most you already covered ;)
alex_s
Postby andrewbishop66 » Sat Jan 06, 2018 10:23 pm
The only thing I would add to that might be 3 point hole centre
for me used when finding centre of engine bore with transfer ports around the circumference
thanks Andrew
andrewbishop66
Postby Dan911 » Sat Jan 06, 2018 11:06 pm
Vmax549 wrote:OK here is a thought we need someone that is good building graphics of teh process we want to display . For example a square pocket. or drawings of the probing routines. I am horrible with graphics.
(;-) TP
You interfaces do look very professional for someone who is not good at it . For now I'm just keeping it simple and working on the program that's getting large and putting out perfect Gcode. The simple create a circle and circular pocket wizard took a lot of time.
Return to Conversational Wizards
