Wizard Plugin
Discuss the creation and usage of Wizards
Re: Wizard Plugin
Postby Dan911 » Tue Jul 03, 2018 10:43 pm
Hi Terry,
Commenting on INC and ABS lines can help in causing confusion to some and is something I will definitely consider adding when/if I do and updated version...Thanks
Vmax549 wrote:ALSO there may be an error in your math on teh 2nd loop as it is still in INC mode and teh Z RAISED by a value of .625. Should it not have lowered by a value of -.125 ??
This is no error, the Z raises after first pass (-.125) to the users set Z travel which is .5 in this case, and moves to start position for final pass -.75.
I edited post to add Gcode for all to test.
Re: Wizard Plugin
Postby Dan911 » Wed Jul 04, 2018 2:36 am
Vmax549 wrote:YEP I did not read it very carefully (;-) I saw my error and edited teh post.
You are doing well with Wizards keep up teh good work.
(;-) TP
Thanks Terry! Just having fun learning and taking advantage of the customizing UCCNC provides.
Re: Wizard Plugin
Postby epracefan@gmail.com » Wed Jul 04, 2018 12:29 pm
Dan911 wrote:
Hi Ed,
You are not doing anything wrong, if you try running code in offline mode or demo mode you will see it runs correctly. I think what you are missing is that after your Z.5 (Z travel setting) move to X6 Y6 there's a
G91(incremental Mode).
You're correct, Dan, I completely overlooked the G91. Thanks for pointing that out.
Ed
epracefan@gmail.com
Re: Wizard Plugin
Postby Dan911 » Sun Sep 30, 2018 2:24 pm
update/fixes
Removed onscreen bool check so can be called with macro CallButton(), needed so can be used with Macro Menu Button plugin.
fixed tab index order.
fixed unhandled Exception in Create Part or Path Wizard.
QuickCam7.zip
(117.88 KiB) Downloaded 2595 times
Re: Wizard Plugin
Postby danowar » Mon Nov 26, 2018 5:52 am
Nice work on this Dan911! I just tried it out briefly. Is this by chance an open source project? I would be willing to help. I also have a few custom wizards I would like to implement in order to maximize some of my typical workflow.
Keep up the good work.
danowar
Re: Wizard Plugin
Postby Dan911 » Tue Nov 27, 2018 1:26 am
Thanks Danowar,
I use this plugin quite often but have a long list of things I want to go back and change. Once the list stops growing I will.
I have a Macro Menu plugin you will find in the toolbox section, there you will also find many wizards most created by Vmax549 that can be added to it or create your own to accommodate your work flow. This is probably a better alternative than the QuickCam plugin and why I slowed in it's progression.
Re: Wizard Plugin
Postby Robertspark » Tue Nov 27, 2018 2:55 pm
senior moment.... :D :roll:
how are we calling this plugin hotkey + buttoncode 6333 doesn't seem to be working
Re: Wizard Plugin
Postby Dan911 » Tue Nov 27, 2018 9:33 pm
Hi Rob,
It's set for 6333, not sure why it's not working for you.
Re: Wizard Plugin
Postby danowar » Sun Dec 02, 2018 2:32 pm
I had a senior moment when installing it also, and forgot to enable the plugin in settings. Things worked much better after that.
Thanks for pointing me at the macros. I had no idea you could program dialog boxes through them. Keep an eye out in the toolbox section, as I am doing some final testing on one I completed.
danowar
Return to Conversational Wizards
