Cut Circle Wizard
Cut Circle Wizard
Postby Vmax549 » Fri Jan 12, 2018 10:11 pm
Here is a VERY simple example of a Wizard made Macro style. I commented teh Script to explain where everything goes and you can see how things are created.
Please leave your comments for this Wizard HERE (;-)
Like I said it is a very simple example. It does not do tool offseting nor does it TOOL RADIUS compensation by tool# it simple cuts on teh centerline.
Play with it and let me know what other things YOU would want to see in a Wizard. Once we can establish a Wizard STANDARD then we can get busy creating other Wizards for UCCNC users.
There are 2 parts to a wizard.
Mcode contains all teh scripting
Graphics file
They both go into your macro Folder.
You can then call it up from the MDI
IF you use graphics files PLEASE use original art IF you are going to publish it here. This is very important. Now if it is for yourself have at it (;-).
One thing you will notice is you do NOT have to use teh mouse to use this Wizard. You simply TAB though all data fields and input teh values then Tab don to teh button and push ENTER. (MouseFree)
Have Fun (;-) TP
M9097.txt
(16.12 KiB) Downloaded 13 times
Vmax549
Re: Cut Circle Wizard
Postby Dan911 » Sat Jan 13, 2018 2:13 am
Nice job Terry! Certainly shows the versatility of UCCNC between macro here and example plugin I posted.
Postby bennyhines70 » Sat Jan 13, 2018 2:27 am
Terry could you use something like this drawing i made with your macro..?
bennyhines70
Postby Vmax549 » Sat Jan 13, 2018 2:47 am
Absolutely could (;-)
Thank you, (;-) TP
NOTE: I just noticed that I did not include all teh file. Here is a zip of teh file for the Wizard. Just unzip it into your macro Folder.
circlewizard.zip
(29 KiB) Downloaded 2 times
Vmax549
Postby Vmax549 » Sat Jan 13, 2018 3:37 am
HIYA DAN, You have not seen anything yet. You can take a clear picture of an OLD control say a Fadal. Load teh picture as a background and input teh data fields over the picture and have a Modern control that LOOKS and feels like teh OLD control GUI.
Want a NEW controller that looks like an old Fanuc ?? NOT a problem (;-)
(;-) TP
Vmax549
Postby Dan911 » Sat Jan 13, 2018 1:32 pm
Vmax549 wrote:HIYA DAN, You have not seen anything yet. You can take a clear picture of an OLD control say a Fadal. Load teh picture as a background and input teh data fields over the picture and have a Modern control that LOOKS and feels like teh OLD control GUI.
(;-) TP
cool...Did something similar with background image but with buttons.
