CNC Lathe Info
Re: CNC Lathe Info
Postby Derek » Sat Nov 04, 2017 9:59 am
cncdrive wrote:
I don't have my UC300ETH connected, but I have the UC300ETH plugin installed, and I don't see what you are seeing when I just tried the wizard.
If it is someking of Mach3 bug then it could be Mach3 version dependent. Maybe you have a different version of mach installed than what Derek has. I did not try the wizard yet though with any versions yet.
It happens when I install the plugin. Before no issues. This is on a clean Mach install version 3.043.062. For my particular lathe there really isn't any reason to run Mach and the UC-300. The PP/HDBB2 seems to working great. I don't seem to have any issues with single index threading. I have an extra UC-300USB and a copy of UCCNC so I thought It would be nice to have all my machines the same. The lathe is the last of my 5 machines that hasn't been converted from Mach.
Derek
Re: CNC Lathe Info
Postby asuratman » Sun Jan 28, 2018 2:04 pm
Vmax,
Do you think building cnc lathe using uccnc/ub1 will be easier than mach3/mach4 ?
asuratman
Re: CNC Lathe Info
Postby Battwell » Mon Feb 05, 2018 7:20 pm
constant surface speed is a must - spindle speeds up as diameter decreases
Uc300eth on router and mill
Re: CNC Lathe Info
Postby Gary Campbell » Mon Feb 05, 2018 7:43 pm
For my wood lathe project not so likely a must, but for metal, most assuredly so. Due to lathe specific approach/exit angles and the ability to define most lathe tooling, along with spindle encoder support, I have moved my lathe (one metal and this small one for wood over to Centroid Acorn control.
Gary Campbell
CNC Technology & Training
Control & ATC Retrofits
gcnc411(at)gmail.com
Gary Campbell
Re: CNC Lathe Info
Postby Derek » Mon Feb 05, 2018 10:39 pm
Battwell wrote:constant surface speed is a must - spindle speeds up as diameter decreases
Only a must if you are doing a lot of facing. I do a fair amount of lathe work and I don't have a VFD so CSS is not an issue. Of course it would be best if it had CSS but for probably a lot of people it isn't a deal breaker. For me tool offsets are the only thing holding me up. Now that there is a tool table with Z and diameter I'm hoping someone with more smarts than me can leverage that into Z and X offsets.
I think everyone is going to have their own must have list. It works now if you reset your tools on every change and can work in radius mode.
Derek
Re: CNC Lathe Info
Postby Derek » Tue Feb 06, 2018 12:23 am
Vmax549 wrote:Derek you COULD do like in teh old days for tool offsets use G52/92s that was long before tool comp.
You could set up teh M6 to handle that automatically.
(;-) TP
I would have to touch off each time I changed tools though wouldn't I? That is a non starter for me.
Derek
Re: CNC Lathe Info
Postby Battwell » Tue Feb 06, 2018 12:50 am
on my biesse conversion i used g52 to offset its 33 different heads.( ie pre measured tooling) i entered their value in a macro- but could just as easily been done from a list of user text fields on screen. (ive used this for tool changer offsets while setting machines up)
Re: CNC Lathe Info
Postby Derek » Tue Feb 06, 2018 1:21 am
Battwell wrote:on my biesse conversion i used g52 to offset its 33 different heads.( ie pre measured tooling) i entered their value in a macro- but could just as easily been done from a list of user text fields on screen. (ive used this for tool changer offsets while setting machines up)
Interesting. So do you think this would be a workable solution for offsets? Realistically I only have like 11 tools for the lathe that I use most of the time.
Derek
