Gcode problem with turning
Posted: Fri Mar 03, 2017 12:26 pm
I know there is not much support for turning yet but I want to use UCCNC for a small Emco lathe I have converted to UCCNC with the UC400ETH and I´m experimenting with Fusion 360.
However I have a problem with the G-code and UCCNC and got ARC ERROR but I cant figure out what the problem is?
Could it be that UCCNC does not support radius movement in the X Z plane?
I have attached a screenshot and the NC file.
Also, the toolpath seem to be somewhat of, the radius shoud not be that long.
If I select a postprocessor without arcs it work fine (like the UCCNC Generic post) but as soon as I use one with arcs like the posts for Mach3 or Fanuc I get the error.
