Gcode problem with turning
Postby JeeyBee » Fri Mar 03, 2017 12:26 pm
I know there is not much support for turning yet but I want to use UCCNC for a small Emco lathe I have converted to UCCNC with the UC400ETH and I´m experimenting with Fusion 360.
However I have a problem with the G-code and UCCNC and got ARC ERROR but I cant figure out what the problem is?
Could it be that UCCNC does not support radius movement in the X Z plane?
I have attached a screenshot and the NC file.
Also, the toolpath seem to be somewhat of, the radius shoud not be that long.
If I select a postprocessor without arcs it work fine (like the UCCNC Generic post) but as soon as I use one with arcs like the posts for Mach3 or Fanuc I get the error.
1.txt
(4.99 KiB) Downloaded 520 times
JeeyBee
Re: Gcode problem with turning
Postby cncdrive » Fri Mar 03, 2017 4:50 pm
Arcs are supported on all planes.
The UCCNC gives you an arc error if the programmed radius*2 is smaller than the distance between the start and the endpoint of the arc, because then the arc is not valid, it mathematically can't be defined.
I think you should check the CAM settings and try to set the arc tolerances tighter, because probably that will be the problem,
because I remember the same problem with Fusion which Autodesk later resolved with setting the tolerances lower in their post.
Postby JeeyBee » Fri Mar 03, 2017 6:49 pm
Problem solved!
The problem was that fusion was set to define the radius with the radius R, but UCCNC seem to want I J K mode.
Sollution: Set useRadius to NO.
JeeyBee
Postby JeeyBee » Fri Mar 03, 2017 6:58 pm
Here are the postprocessors for mill and turn.
I have lowered the tolerance to 0.01mm
Changed use radius to false
Added turn capability to be able to use the postprocessor in a turn operation.
Otherwise its nothing special for turning in the turn post bit that will hopefully be added soon.
UCCNC-Turn.zip
(7.12 KiB) Downloaded 497 times
UCCNC-Mill.zip
(7.09 KiB) Downloaded 469 times
JeeyBee
Postby JeeyBee » Fri Mar 10, 2017 3:30 pm
I corrected an error in the Millpost.
UCCNC-Turn.zip
(7.11 KiB) Downloaded 490 times
UCCNC-Mill.zip
(7.09 KiB) Downloaded 457 times
JeeyBee
