Error in User Manual
Postby ger21 » Sun Dec 24, 2017 4:08 pm
On Page 16 of the User Manual, Enable is labelled Enable port port & pin.
And this line was apparently copied from the Step Port & Pin, and should be removed.
Which is the physical output pin on the UC100 device for the step signal.
Re: Error in User Manual
Postby cncdrive » Thu Dec 28, 2017 4:05 pm
Thanks Gerry, I've corrected the errors now in the documentation.
