CV tolerances
CV tolerances
Postby rowka » Sun Dec 24, 2017 2:59 pm
Is it possible to set the CV tolerances in G-code?
I have jobs with some features that require tight tolerance (machine slows down) and others that can be quite a bit looser where I take advantage of higher machining speeds.
Rather than make individual toolpaths and making the adjustments manually, is there another way?
rowka
Re: CV tolerances
Postby dezsoe » Sun Dec 24, 2017 4:10 pm
Yes, see G64 in the manual for parameters.
Re: CV tolerances
Postby rowka » Mon Dec 25, 2017 4:28 pm
That’s it! Thank you very much.
Now to figure out how to modify my posts to add them. ;)
rowka
