Uccnc + scananything ?
Postby Robertspark » Sat Nov 04, 2017 9:52 am
http://www.sheetcam.com/Scanything/index
Just wondering, as I saw a method posted yesterday if developing a plugin for scananything >> uccnc was a little more feasible now through the use of the method given here? (To directly control an axis)
AddLinearMoveRel(int Axis, double Step, int StepCount, double Speed, bool Dir
viewtopic.php?f=4&t=843
Don't believe I'd seen this method / function before in the documentation
Rob
UCCNC v1.2108 Macro Manual
Re: Uccnc + scananything ?
Postby cncdrive » Sun Nov 05, 2017 10:33 am
Yes, this method is hidden in the plugin interface, because we did not want to make it fully public, because it directly calling the API, adding motion directly into the motion buffer without using the g-code interpreter of the UCCNC, and we were afraid that if the function prototype goes fully public then people might use it incorrectly and we will then have a hard time to debug 3rd party plugins if there will be problems with the plugin calling this function.
So, the function is in the plugin interface, but we disabled it in the Intellisense, so the C# compliler (e.g. VisualStudio) will not show you the function prototype.
But if a function call is typed correctly then it still works.
And we advice to use this function in pendant plugins for step jog movements, we used the same in the HB04 and UCR200 pendants and it works fine.
Postby 1JUMPER10 » Mon Nov 06, 2017 5:54 am
Robert - are you working on a plugin for scanything? If you need a beta tester I'm volunteering. :D
1JUMPER10
Postby Robertspark » Tue Nov 07, 2017 6:11 pm
Hi Terry, to be fair I got quite a favourable response from Les
http://forum.sheetcam.com/viewtopic.php?t=7613
But in the meantime I also had a pondering look at how line following robots work and more specifically those that use a camera, and came across OpenCV, and it's c# wrapper Emgu CV of which OpenCV has been used with raspberry pi / beagle bone for line following robots.
I guess the concern I have is the cost of the API given scananything costs £50 I think it is which is not a lot in my mind although I'm uncertain how pricing an API would work whilst still being sufficient for the developer to obtain some remuneration for their work.
Rob
Postby Robertspark » Tue Nov 07, 2017 6:36 pm
I am also aware that one of the unique features of UCCNC + UC motion controllers is the serial number + licenced to name.
Hence via field 906 and 901 it is possible within the plugin to allow for registration of plugins for remuneration (although I've never seen the need to do it / created anything that would warrent such a charging arrangement).
But there is the possibility however to use such an arrangement.
Rob
Postby sngatlanta » Tue Apr 17, 2018 10:12 pm
Did anything ever develop from this? I would be very interested in the capability.
sngatlanta
Postby Robertspark » Tue Apr 17, 2018 11:28 pm
No, best use mach3 with the UC motion controllers
Rob
Postby sngatlanta » Wed Apr 18, 2018 2:25 pm
It's possible to run mach3 from my 300eth/ub1 combination?
sngatlanta
Postby dezsoe » Wed Apr 18, 2018 2:30 pm
Yes. UC300ETH (the core on the UB1) works with Mach3. See http://www.cncroom.com/interface-cards/ub1.
Postby Robertspark » Wed Apr 18, 2018 2:31 pm
Oh yes, most definitely.
Mach3 plugin here (+_MAch4 too)
https://www.cncdrive.com/UC300ETH.html
You'll obviously need to setup the profile with all your ports and pins etc as per normal.
Rob
Users browsing this forum: Bing [Bot] and 7 guests
