by cncdrive » Fri Jan 31, 2025 3:31 pm
The XP- and YP- and ZP- etc. are the step signals for the stepper drives and these go to the step outputs of the AXBB-E. The XD- and YD-, ZD- are the direction signals, these go to the Dir outputs of the AXBB-E.
The 5V is the +5V of the AXBB-E.
The Home, e-stop, home etc. you can connect to any isolted inputs of the AXBB-E, because all I/Os are frelly configurable in software, there are no fixed functions like with the cheap Chinese controllers.
They fix functions to fixed pins just to save costs.
And the analog signal you can connect to the analog 0-10V output of the AXBB-E and you could use one isolated output for start signal and one for direction signal for the VFD.
