mobile and fixed probe pins
PostPosted: Wed Sep 04, 2024 12:58 pm
by chrisdax
basic question but i can't find the info in the manual,
in UCCNC / SETTINGS / I/O SETUP1 : probe 1 and probe 2 pins : wich one is the fixed probe and wich one is the mobile probe ?
Christophe
Re: mobile and fixed probe pins
PostPosted: Wed Sep 04, 2024 7:17 pm
Both probe inputs are identical.
Both using the same G31 code, so it does not matter which probe is what type.
PostPosted: Thu Sep 05, 2024 2:12 pm
by chrisdax
ok, but in UCCNC when you probe, how to choose wich one will be used and how the soft knows wich input to listen to ?
Christophe
PostPosted: Thu Sep 05, 2024 8:31 pm
Hi Christophe,
The UCCNC listens to both inputs all the time, you can't select and do not have to select that, because one time you only probe with one sensor, the other is inactive for that time.
PostPosted: Fri Sep 06, 2024 8:41 am
by chrisdax
ok i understand now :-)))
thanks !
