Spindle up to speed confirmation
Postby bhdavis » Tue Aug 20, 2024 2:03 pm
Is there a SPINDLE UP TO SPEED confirmation feature in UCCNC?
Up to now I've just been adding a P4 dwell command in my code to give time for the spindle to come up to speed. I believe some control packages have a way to confirm the spindle is up to speed before proceeding. Is that the case with UCCNC?
BH
bhdavis
Re: Spindle up to speed confirmation
Postby ger21 » Tue Aug 20, 2024 11:46 pm
There's a delay after spindle start in UCCNC, which basically does the same thing as your dwell. But there's no built in functionality to wait for a signal from the VFD before continuing.
Postby bhdavis » Wed Aug 21, 2024 12:07 am
Thanks.
BH
bhdavis
Postby cncdrive » Wed Aug 21, 2024 1:16 am
There is a wait for spindle function in the UCCNC 1.2117 which waits for the spindle to reach the programmed velocity, but for that you need an Index sensor or an encoder which measures the spindle speed.
Postby valhallaCNC » Wed Aug 21, 2024 1:30 am
I use a modified M3 macro. I get the actual speed from my vfd and compare it to the set speed when the speed is reached then the machine will move. Works great.
valhallaCNC
Postby ger21 » Wed Aug 21, 2024 2:32 am
cncdrive wrote:There is a wait for spindle function in the UCCNC 1.2117 which waits for the spindle to reach the programmed velocity, but for that you need an Index sensor or an encoder which measures the spindle speed.
You should have an option for an input from the VFD.
