Probe X and Y problem
Postby samsonwilliams » Fri Apr 19, 2024 7:58 am
AXBB-E and UCCNC
If I make a Z probe then an X and Y probe on a plate placed approximately on the bed, the cutter will be placed on zero X; zero Y and zero Z correctly BUT it will not keep the X and Y axis therefore the X and the Y will not follow the reference part but the X and Y axis of the milling machine... I hope Made me understand and do you have a solution so that the probe can compensate for the bad placement of my raw material on the bed?
Thanks for your help or advice.
samsonwilliams
Re: Probe X and Y problem
Postby eabrust » Fri Apr 19, 2024 1:57 pm
samsonwilliams wrote:AXBB-E and UCCNC
Sounds like you want to know what to do about rotation of the material on the table. Do a little research in the forum or in manual (or google...) on use of G68 (coordinate rotations).
With use of a few probing routines, you can set a corner to 0 as you've done already, then go and run another probe routine and rotate the coordinates by probing an edge to get the angle.
Users browsing this forum: Battwell and 15 guests
