400 to 449 - SelectTABlayer - Selects the TAB layer on the screen. The layer number selected is the function code - 400, so TAB layer 1. selected with code 401. Note: To select a sub layer with a hotkey or with an input trigger configure the same key or pin to select all of it's parent layers and also the layer itself, so the parent layers and the sub layers will also be selected and the sub layer will always showup this way, no matter which parent layer was originally shown.
