Retrofit Haas Mini Mill to UCCNC
Posted: Wed Mar 06, 2024 5:28 am
I am considering retrofitting my Haas mini mill to UCCNC or maybe Centroid
I have done at least 20 UCCNC setups on hobby stuff so leaning more towards UCCNC and I have 4 of my own machines with it.
Long story but I have a 2019 Haas mini mill and have just resurrected it after it was full flooded under water for 2 days. I have replaced all the bearings and cleaned everything , I have checked and the next gen control is all functioning and was working all ok .
I have never run this machine before and had to install a phase changer to get the 415V AC three phase hookup . on testing I found that if the spindle was ramped up as a direct on it drew too much current and shut the whole system down completely with a low voltage alarm then contactors dropped out. If I ramped the rpm slowly from 1000 to the max of 10 000rpm it was fine.
Now on all my other machines I would go into the VFD and slow the acceleration of the spindle down , HAAS run a vector drive which is controlled by the controller and here is where I run into my first problem - all the parameters are locked out and to be able to gain access to a service key to modify I was quoted 11k
Second issue was that since I had removed the drive belt the motor encoder was not synched with the spindle orientation required for a tool change - again another parameter with no access to , a tech from haas would need to come out to do that , I am 600kms away from any tech
on talking to some friend it was suggested the true 240 v leg the controller operates off may be on the wrong leg of the transformer so I swapped 2 phases over - this would normally just reverse direction of the motor BUT in this case it shorted out the vector drive causing a DC bush short error - next issue 10K for a new vector drive.
So as it stands I am looking at going back to my original though when I bought the flooded unit.
The issues as I see it
1. UCCNC cant drive the axis drives ( I would need to buy new compatable ones - not haas) in closed loop feedback mode , only step and direction.
2. Rigid tapping control with a spindle encoder/servo setup
3. Homing switches needed as the servo encoder cannot be read anymore as different drives
4. I find the homing switches of various types are not accurate enough to give repeatability to use zero point fixtures.
5. Geneva Toolchanger carousel uses dc motors for rotation and feeding in
6. Integrating the renishaw wireless probing system and all its complex macros
7. Fusion part probing routines not working
8. Most probably more important - will the control system be able to get the control and surface finishes a industrial control has ?
Hopefully anyone who has encountered these issue and overcome them will chime in with a solution.
