What units are used?
Postby champ96 » Wed Feb 14, 2024 9:26 pm
Hi
When trying to make the constant velocity mode work well I have a question.
What units are used here?
Linear error max, Linear addition length max, Linear unify length max, Corner error max, Arc radius tolerance.
Is it Millimeters, percent or what??
champ96
Re: What units are used?
Postby dezsoe » Thu Feb 15, 2024 9:41 am
The units that you set up your machine. When you set up the steps/unit for the axes then you have to decide what a unit is: millimeters or inches. All other places where you have to set something in units are the same units. Note that the default values for the CV settings (except for the "Stop at angle degrees") are given in millimeters, so you have to convert them to inches if you use inches.
