Demo mode
Demo mode
Postby HughR » Mon Nov 13, 2023 6:31 pm
I am unable to get my UCCNC software out of demo mode.
I have pasted the licence key file into the UCCNC folder as a text file as sent to me but it will not activate the software.
It was working fine 3 months ago. Where do I look/check? I am a new user so treat with kidd gloves!!
Thanks for your help
HughR
Re: Demo mode
Postby HughR » Tue Dec 12, 2023 8:08 pm
I have tried uninstalling the software and then reinstalling it from the UCCNC website. It appears to load ok and I have paster in the key when requested but I am still in demo mode. The numbers match between the board and the code.
Where else should I look. I can't believe there is noone on this forum who can solve this for me.
Thanks in advance
Hugh
HughR
Re: Demo mode
Postby dezsoe » Tue Dec 12, 2023 10:11 pm
If you have UC100 then check these instructions or if you have an Ethernet motion controller then you have to configure its network. If you don't write any information then noone can help.
Re: Demo mode
Postby HughR » Wed Dec 13, 2023 8:39 pm
it is a UC300ETH v4.0
It is not on a network it is connected to my computer via an ethernet cable
I have got orange lights on but it used to hace a blue light I think when it worked.
what other information would help
thanks
Hugh
HughR
Re: Demo mode
Postby ger21 » Wed Dec 13, 2023 8:59 pm
Do you have the network adapter configured correctly?
Re: Demo mode
Postby HughR » Thu Dec 14, 2023 8:43 am
I guess it was as the machine used to run. I did not set it up originally. But it stopped working so I reinstalled the software. Do I need to update the network driver. If so how do I do that?
HughR
Re: Demo mode
Postby Battwell » Thu Dec 14, 2023 9:58 am
follow the uccnc manual for your uc300
how to set up the network.
go to network & internet settings.
ethernet
change adapter options.
you need to change the properties of your ipv4 in the drop down list
set to
10.10.10.175
subnet 255.255.255.0
gateway. leave blank.
validate on exit checked.
close.
Re: Demo mode
Postby HughR » Fri Dec 15, 2023 4:00 pm
Thanks I will reread that section and give it a go.
Hugh
HughR
Users browsing this forum: Google [Bot] and 6 guests
