ucr201 questions
ucr201 questions
Postby kirkmiller » Wed Jul 12, 2023 4:52 pm
Session to session I always have to go into the config panel to change the number of digits displayed.
I do load a profile after initialization from the default profile.
Question 1: How do I get the settings to save as the session update and save in the desired profile don't seem to save the UCR201 init's?
Question 2: I lose contact with the USB receiver, even though the pendant and usb receiver are very close and RF signal strength is at full antenna, any suggestions to improve?
kirkmiller
Re: ucr201 questions
Postby ger21 » Thu Jul 13, 2023 10:59 am
1) On your desktop shortcut, the profile name should be in the "Target", like this: C:\UCCNC\UCCNC.exe /p Profilename
2) Make sure all the power saving options are turned off in your PC for the USB ports.
Postby kirkmiller » Thu Apr 25, 2024 8:01 pm
I looked but couldn't find any power saver options for the USB port in Windows 10. The loss of connection is very intermittent and can happen a few times with a minute, which seems way too fast for a power saving mode to kick in.
We have found that there might be some interference that causes position jumps when the MPG is enabled when a bluetooth loudspeaker in the next room is being used. I haven't tried changing the radio channels yet, are there any less likely to interfere channels?
kirkmiller
Postby ger21 » Fri Apr 26, 2024 10:47 am
Go to Device Manager, and dig deep into the USB ports properties and settings.
Users browsing this forum: Google [Bot] and 27 guests
