cncdrive wrote:Usually this false conclusion in uers head comes from a misunderstanding of what rapid feedrate it.
For example you set the valocity to 10000 on X and 10000 on Y then the rapid feedrate on the XY plane is not 10000, but 14400 max. and that case is when the XY runs the same distance, in other words when there is a 45°diagonal movement then the rapid is 14400.
We having many users missunderstanding how this works and getting threatened by seeing higher feedrates as the max. they set for an individual axis, but this is not a bug, it is how the rapid feedrate works in CNC controllers.
