Thoughts on current Safe Z implementation.
Postby ger21 » Fri Nov 04, 2016 1:45 am
It appears that the way the SafeZ value is currently used in UCCNC, is that SafeZ is in work coordinates.
This has a major disadvantage, in that the SafeZ position will move with varying material thickness, or fixture height.
Mach3 gives you an option to specify Safe Z in Machine Coordinates. This is a better option, imo, as it gives a consistent SafeZ height that won't allow a crash into the upper Z axis limit.
Any thoughts?
Re: Thoughts on current Safe Z implementation.
Postby ger21 » Fri Nov 04, 2016 2:43 pm
When it's in Work Coordinates, I agree.
The issue here is that you don't exactly have a choice. It's used when you click the Stop button, and Run from Here. (but you can edit it when using Run from here).
Postby ger21 » Fri Nov 04, 2016 4:06 pm
Vmax549 wrote:
I could be wrong (;-)
So could I. :lol:
Postby CT63 » Mon Nov 07, 2016 8:30 pm
I would like to see the option of selecting safe Z in work or machine coordinates. I prefer to use machine coordinates safe Z.
CT63
Postby ger21 » Mon Nov 07, 2016 8:41 pm
In the screenset I'm making, I added a second Safe Z that can be set in Machine coordinates. The default is use for Run From Here, and the added one will be used for auto zero and toolchange routines.
