Ok, I am just starting to set up the uc300eth-ub1 on my XP system.
I am using direct cable connection between systems (no router).
I have configured the IP address for the XP ethernet adpater per documents ( IP address 10.10.10.10, subnet mask 255.255.255.0).
I can ping the uc300eth at ip 10.10.10.11 and it answers the ping correctly so I am assuming the communications are working.
However when I try to run UCxxx._utility.exe to scan for the uc300eth however it fails. I get "Application has failed to start because the application configuration is incorrect".
Is there a way to fix this or am I using the wrong utility (only see one .exe file of them in the zip file, but there is another file called ftd2xx.dll, does this need to be put in some systemfile folder?)
thanks mike
