Sorry should have been more specific. Thanks for the help
Pictures are worth a thousand words.
https://photos.app.goo.gl/ebzyqEwgpgQJE6HT6https://photos.app.goo.gl/FGd6YfEpZki4zQk5Ahttps://photos.app.goo.gl/MtzEKw4KdGYnyEbY9https://photos.app.goo.gl/9ZKbRTCWLWTcvt4V9https://photos.app.goo.gl/8DFvnj1WsPHRUc466(Don't think images will post so I provided links as well)
Generic Circle- I designed a circular pocket about 5" in diameter and about 7/16" deep to be done in 3 passes. As the CNC would make the helical plunge cut to start the pocket it would be a perfect circle, once the helical plunge cut reached the final depth and it started to work out the final diameter the circle was almost a perfect multi faceted circle. see pic above.
I read that I may need to adjust the Constant Velocity setting from the stock setting, does this sound accurate?
G43-I see...I should never need G43 because when I do a tool change I would have to reset Z to the new tool height manually, am I understanding that correctly? How do I have fusion stop generating the G43 code or should I just manually delete it every time? I looked at the Post Processing file and that is way over my head to manipulate, I am definitely not a coder.
My Setup:
UCCNC version 1.0249 with Gerry's 2017 Screenset from thecncwoodworker.com
UC100
3 axis router 4'x6' bed with y being the 6' section
I have no offsets set
I have it set to the standard xyz configuration, nothing reversed, machine home is the front left of the machine as I am looking at it from the front.
If I remember correctly I have my stepperdriver set to 1/4 microsteps (800 microsteps per revolution)
My z axis is a screw drive at about 5000 steps per inch and xy are belt drive at about 500 steps/inch velocity
As far as Gcode I am mildly familiar with it, I have to keep a reference sheet handy, I looked up all the M and G codes after I had the problem but I could not figure it out which is why I posted the question.
Here is more of the code, It is several hundred lines long but here is much more of it.
(T1 D=0.5 CR=0. - ZMIN=-0.6553 - dovetail mill)
G90
G0 G53 Z0.
(2D Adaptive3)
T1 M6 (dovetail mill D=0.5 1/2 bit Andy)
S5000 M3
G64
G54
M8
G43 H1
G0 X-0.0926 Y0.2187
Z0.5906
Z0.1969
Z0.0984
G3 X-0.2187 Y-0.0926 Z0.0854 I0.0926 J-0.2187 F33.33
X0.0926 Y-0.2187 Z0.0724 I0.2187 J0.0926
X0.2187 Y0.0926 Z0.0593 I-0.0926 J0.2187
X-0.0926 Y0.2187 Z0.0463 I-0.2187 J-0.0926
X-0.2187 Y-0.0926 Z0.0333 I0.0926 J-0.2187
X0.0926 Y-0.2187 Z0.0203 I0.2187 J0.0926
X0.2187 Y0.0926 Z0.0072 I-0.0926 J0.2187
X-0.0926 Y0.2187 Z-0.0058 I-0.2187 J-0.0926
X-0.2187 Y-0.0926 Z-0.0188 I0.0926 J-0.2187
X0.0926 Y-0.2187 Z-0.0319 I0.2187 J0.0926
X0.2187 Y0.0926 Z-0.0449 I-0.0926 J0.2187
X-0.0926 Y0.2187 Z-0.0579 I-0.2187 J-0.0926
X-0.2187 Y-0.0926 Z-0.0709 I0.0926 J-0.2187
X0.0926 Y-0.2187 Z-0.084 I0.2187 J0.0926
X0.2187 Y0.0926 Z-0.097 I-0.0926 J0.2187
X-0.0926 Y0.2187 Z-0.11 I-0.2187 J-0.0926
X-0.2187 Y-0.0926 Z-0.123 I0.0926 J-0.2187
X0.0926 Y-0.2187 Z-0.1361 I0.2187 J0.0926
X0.2187 Y0.0926 Z-0.1491 I-0.0926 J0.2187
X-0.0926 Y0.2187 Z-0.1621 I-0.2187 J-0.0926
X-0.2187 Y-0.0926 Z-0.1752 I0.0926 J-0.2187
X0.0926 Y-0.2187 Z-0.1882 I0.2187 J0.0926
X0.2187 Y0.0926 Z-0.2012 I-0.0926 J0.2187
X-0.0926 Y0.2187 Z-0.2142 I-0.2187 J-0.0926
X-0.2187 Y-0.0926 Z-0.2273 I0.0926 J-0.2187
X0.0926 Y-0.2187 Z-0.2403 I0.2187 J0.0926
X0.2375 Y0. Z-0.25 I-0.0926 J0.2187
X0. Y0.2375 I-0.2375 J0.
X-0.2375 Y0. I0. J-0.2375
X0. Y-0.2375 I0.2375 J0.
X0.2375 Y0. I0. J0.2375
G1 X0.2377 Y0.0132 F50
X0.2393 Y0.0263
X0.2518 Y0.0777
X0.2534 Y0.0812
X0.2565 Y0.0888
X0.2593 Y0.0975
X0.2616 Y0.1072
X0.2632 Y0.118
X0.264 Y0.1298
X0.2639 Y0.1425
X0.2626 Y0.1561
X0.2601 Y0.1704
X0.2562 Y0.1854
X0.2509 Y0.2009
X0.2439 Y0.2168
X0.2353 Y0.2328
X0.225 Y0.2488
X0.2128 Y0.2646
X0.1989 Y0.28
X0.1833 Y0.2948
X0.1659 Y0.3087
X0.1468 Y0.3216
X0.1262 Y0.3333
X0.1042 Y0.3435
X0.0808 Y0.3521
X0.0562 Y0.359
X0.0307 Y0.364
X0.0044 Y0.367
X-0.0225 Y0.3679
X-0.0498 Y0.3666
X-0.0773 Y0.3631
X-0.1047 Y0.3573
X-0.1318 Y0.3492
X-0.1584 Y0.3389
X-0.1843 Y0.3264
X-0.2094 Y0.3118
X-0.2333 Y0.295
X-0.2559 Y0.2764
X-0.2771 Y0.2558
X-0.2966 Y0.2335
X-0.3144 Y0.2097
X-0.3302 Y0.1844
X-0.344 Y0.1578
X-0.3556 Y0.1302
X-0.365 Y0.1016
X-0.3721 Y0.0723
X-0.3768 Y0.0425
X-0.3792 Y0.0124
X-0.3791 Y-0.0179
X-0.3765 Y-0.0481
X-0.3716 Y-0.078
X-0.3642 Y-0.1075
X-0.3545 Y-0.1363
X-0.3426 Y-0.1642
X-0.3284 Y-0.1912
X-0.312 Y-0.2169
X-0.2937 Y-0.2412
X-0.2735 Y-0.2639
X-0.2515 Y-0.285
X-0.2278 Y-0.3043
X-0.2027 Y-0.3216
X-0.1763 Y-0.3368
X-0.1487 Y-0.3499
X-0.1202 Y-0.3607
X-0.0909 Y-0.3692
X-0.061 Y-0.3753
X-0.0307 Y-0.379
X-0.0002 Y-0.3803
X0.0303 Y-0.379
X0.0606 Y-0.3754
X0.0906 Y-0.3693
X0.1199 Y-0.3609
X0.1485 Y-0.3501
X0.1761 Y-0.3371
