Interesting thing I just observed playing, with current settings, small Helical (boring 10mm hole with 6mm OD) motion in XYZ is smooth?
How come is this possible?
Anyways, going changing setup and see if it improoves.
G91
F3000
M98 P201 L20
M98 P202 L20
G90
G0 X0
M30
O201
G1 Y250
G1 X250
G1 Y-250
G1 X-250
M99
O202
G1 X250
G1 Y250
G1 X-250
G1 Y-250
M99
Robertspark wrote:I kind of wish there was two lots of planer tolerance settings one for roughing and another for finishing cuts, that way you get the benefit of faster roughing cuts that have the same feedrate however lower tolerance on blended motion and then for the final cut you can reduce the tolerances
ger21 wrote:
You can change the settings in your g-code, so that you can use different settings for roughing and finishing.
Set Path Control Mode to constant velocity : G64
Program G64 D... E... H... L... P... Q... to put the machine into constant velocity path control mode.
All parameters are optional. If any parameters are left out (not programmed) then the software will
get that parameter's value from the screen settings.
The parameter D is the Stop angle setting.
The parameter E is the Lookhead lines setting.
The parameter H is the Linear error setting.
The parameter L is the Linear addition length setting.
The parameter P is the Unify length setting.
The parameter Q is the Corner error setting.
