I set up two short g-codes files using Aspire 8.5 and Aspire 9.5 to test the M6. I ran the test seven times using different scenarios each time. i.e. restart UCCNC between test cuts, changing the file between test, I even hide in the corner out of sight of the CNC so it wouldn't know I was watching.
The results was............. The M6 worked every time even with a tool number larger than 100. So I'm at a loss at being able to duplicate the problem. As I said before this skipping of the M6 does not happen very often, maybe 1 in 10 times, but if I'm not watching it sure will ruin a project.
Here's one of the code files made with Aspire 9.5:
( Test M6 Tool Change Number 2 )
( File created: Monday December 17 2018 - 06:49 AM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 11.000, Y= 8.000, Z= 0.750)
(Toolpaths used in this file:)
(Profile 1)
(Profile 2)
(Profile 3)
(Profile 4)
(Tools used in this file: )
(12 = End Mill {0.125 inch})
(1001 = End Mill {0.06 inch})
(61 = End Mill {0.125 inch}PVC Plastic)
(101 = End Mill {0.25 inch})
N160G00G20G17G90G40G49G80
N170G70G91.1
N190 (Tool: End Mill {0.125 inch})
N200G00G43Z0.3937H12
N210S24000M03
N220(Toolpath:- Profile 1)
N230()
N240G94
N250X0.0000Y0.0000F100.0
N260G00X-2.1612Y1.3369Z0.1181
N270G1X-2.1612Y1.3369Z-0.1250F30.0
N280G3X-2.7862Y1.9619I-0.6250J0.0000F100.0
N290G3X-3.4112Y1.3369I0.0000J-0.6250
N300G3X-2.7862Y0.7119I0.6250J0.0000
N310G3X-2.1612Y1.3369I0.0000J0.6250
N320G1X-2.1612Y1.3369Z-0.2500F30.0
N330G3X-2.7862Y1.9619I-0.6250J0.0000F100.0
N340G3X-3.4112Y1.3369I0.0000J-0.6250
N350G3X-2.7862Y0.7119I0.6250J0.0000
N360G3X-2.1612Y1.3369I0.0000J0.6250
N370G00X-2.1612Y1.3369Z0.1181
N380T1001M6
N390 (Tool: End Mill {0.06 inch})
N400G43H1001
N410S24000M03
(Profile 2)
N440G00X-0.9287Y0.7419Z0.1181
N450G1X-0.9287Y0.7419Z-0.1250F30.0
N460G2X-1.5237Y1.3369I0.0000J0.5950F100.0
N470G2X-0.9287Y1.9319I0.5950J0.0000
N480G2X-0.3337Y1.3369I0.0000J-0.5950
N490G2X-0.9287Y0.7419I-0.5950J0.0000
N500G1X-0.9287Y0.7419Z-0.2500F30.0
N510G2X-1.5237Y1.3369I0.0000J0.5950F100.0
N520G2X-0.9287Y1.9319I0.5950J0.0000
N530G2X-0.3337Y1.3369I0.0000J-0.5950
N540G2X-0.9287Y0.7419I-0.5950J0.0000
N550G00X-0.9287Y0.7419Z0.1181
N560T61M6
N570 (Tool: End Mill {0.125 inch}PVC Plastic)
N580G43H61
N590S20000M03
(Profile 3)
N620G00X1.1654Y0.7744Z0.1181
N630G1X1.1654Y0.7744Z-0.1250F6.0
N640G2X0.6029Y1.3369I0.0000J0.5625F25.0
N650G2X1.1654Y1.8994I0.5625J0.0000
N660G2X1.7279Y1.3369I0.0000J-0.5625
N670G2X1.1654Y0.7744I-0.5625J0.0000
N680G1X1.1654Y0.7744Z-0.2500F6.0
N690G2X0.6029Y1.3369I0.0000J0.5625F25.0
N700G2X1.1654Y1.8994I0.5625J0.0000
N710G2X1.7279Y1.3369I0.0000J-0.5625
N720G2X1.1654Y0.7744I-0.5625J0.0000
N730G00X1.1654Y0.7744Z0.1181
N740T101M6
N750 (Tool: End Mill {0.25 inch})
N760G43H101
N770S24000M03
(Profile 4)
N800G00X2.2965Y1.3369Z0.1181
N810G1X2.2965Y1.3369Z-0.1250F30.0
N820G3X3.0465Y0.5869I0.7500J0.0000F100.0
N830G3X3.7965Y1.3369I0.0000J0.7500
N840G3X3.0465Y2.0869I-0.7500J0.0000
N850G3X2.2965Y1.3369I0.0000J-0.7500
N860G1X2.2965Y1.3369Z-0.2500F30.0
N870G3X3.0465Y0.5869I0.7500J0.0000F100.0
N880G3X3.7965Y1.3369I0.0000J0.7500
N890G3X3.0465Y2.0869I-0.7500J0.0000
N900G3X2.2965Y1.3369I0.0000J-0.7500
N910G00X2.2965Y1.3369Z0.1181
N920G00Z0.3937
N930G00X0.0000Y0.0000
N940M09
N950M30
Here is the other file made with Aspire 8.5:
( Testing M6 Tool Change )
( File created: Wednesday October 31 2018 - 12:29 PM)
( Material Size)
( X= 14.000, Y= 11.000, Z= 0.750)
(Profile 1)
(Profile 2)
(V-Carve 1)
(1 = End Mill {0.25 inch})
(2 = V-Bit {90 deg 1.25"})
(101 = Ball Nose {0.25 inch})
N140G00G20G17G90G40G49G80
N150G70G91.1
N160T1M06
N170 (Tool: End Mill {0.25 inch})
N180G00G43Z0.8000H1
N190S12000M03
N200(Toolpath:- Profile 1)
N210()
N220G94
N230X0.0000Y0.0000F100.0
N240G00X1.5989Y5.0750Z0.2000
N250G1X1.5989Y5.0750Z-0.1250F30.0
N260G2X1.1739Y5.5000I0.0000J0.4250F100.0
N270G2X1.5989Y5.9250I0.4250J0.0000
N280G2X2.0239Y5.5000I0.0000J-0.4250
N290G2X1.5989Y5.0750I-0.4250J0.0000
N300G00X1.5989Y5.0750Z0.2000
N310T2M6
N320 (Tool: V-Bit {90 deg 1.25"})
N330G43H2
N340S12000M03
(Profile 2)
N370G00X3.3304Y5.0250Z0.2000
N380G1X3.3304Y5.0250Z-0.1250F30.0
N390G3X3.8054Y5.5000I0.0000J0.4750F50.0
N400G3X3.3304Y5.9750I-0.4750J0.0000
N410G3X2.8554Y5.5000I0.0000J-0.4750
N420G3X3.3304Y5.0250I0.4750J0.0000
N430G00X3.3304Y5.0250Z0.2000
N440T101M6
N450 (Tool: Ball Nose {0.25 inch})
N460G43H101
N470S12000M03
(V-Carve 1)
N500G00X5.4779Y5.4750Z0.2000
N510G1X5.4779Y5.4750Z-0.1251F30.0
N520G1X5.6279Y5.4750Z-0.1251F100.0
N530G1X5.6279Y5.5250Z-0.1251
N540G1X5.4779Y5.5250Z-0.1251
N550G1X5.4779Y5.4750Z-0.1251
N560G1X5.4529Y5.4500Z-0.1251
N570G1X5.6529Y5.4500Z-0.1251
N580G1X5.6529Y5.5500Z-0.1251
N590G1X5.4529Y5.5500Z-0.1251
N600G1X5.4529Y5.4500Z-0.1251
N610G1X5.4279Y5.4250Z-0.1251
N620G1X5.6779Y5.4250Z-0.1251
N630G1X5.6779Y5.5750Z-0.1251
N640G1X5.4279Y5.5750Z-0.1251
N650G1X5.4279Y5.4250Z-0.1251
N660G1X5.4029Y5.4000Z-0.1251
N670G1X5.7029Y5.4000Z-0.1251
N680G1X5.7029Y5.6000Z-0.1251
N690G1X5.4029Y5.6000Z-0.1251
N700G1X5.4029Y5.4000Z-0.1251
N710G1X5.3779Y5.3750Z-0.1251
N720G1X5.7279Y5.3750Z-0.1251
N730G1X5.7279Y5.6250Z-0.1251
N740G1X5.3779Y5.6250Z-0.1251
N750G1X5.3779Y5.3750Z-0.1251
N760G1X5.3529Y5.3500Z-0.1251
N770G1X5.7529Y5.3500Z-0.1251
N780G1X5.7529Y5.6500Z-0.1251
N790G1X5.3529Y5.6500Z-0.1251
N800G1X5.3529Y5.3500Z-0.1251
N810G1X5.3279Y5.3250Z-0.1251
N820G1X5.7779Y5.3250Z-0.1251
N830G1X5.7779Y5.6750Z-0.1251
N840G1X5.3279Y5.6750Z-0.1251
N850G1X5.3279Y5.3250Z-0.1251
N860G1X5.3029Y5.3000Z-0.1251
N870G1X5.8029Y5.3000Z-0.1251
N880G1X5.8029Y5.7000Z-0.1251
N890G1X5.3029Y5.7000Z-0.1251
N900G1X5.3029Y5.3000Z-0.1251
N910G1X5.2779Y5.2750Z-0.1251
N920G1X5.8279Y5.2750Z-0.1251
N930G1X5.8279Y5.7250Z-0.1251
N940G1X5.2779Y5.7250Z-0.1251
N950G1X5.2779Y5.2750Z-0.1251
N960G1X5.2529Y5.2500Z-0.1251
N970G1X5.8529Y5.2500Z-0.1251
N980G1X5.8529Y5.7500Z-0.1251
N990G1X5.2529Y5.7500Z-0.1251
N1000G1X5.2529Y5.2500Z-0.1251
N1010G1X5.2279Y5.2250Z-0.1251
N1020G1X5.8779Y5.2250Z-0.1251
N1030G1X5.8779Y5.7750Z-0.1251
N1040G1X5.2279Y5.7750Z-0.1251
N1050G1X5.2279Y5.2250Z-0.1251
N1060G1X5.2029Y5.2000Z-0.1251
N1070G1X5.9029Y5.2000Z-0.1251
N1080G1X5.9029Y5.8000Z-0.1251
N1090G1X5.2029Y5.8000Z-0.1251
N1100G1X5.2029Y5.2000Z-0.1251
N1110G1X5.1779Y5.1750Z-0.1251
N1120G1X5.9279Y5.1750Z-0.1251
N1130G1X5.9279Y5.8250Z-0.1251
N1140G1X5.1779Y5.8250Z-0.1251
N1150G1X5.1779Y5.1750Z-0.1251
N1160G1X5.1529Y5.1500Z-0.1251
N1170G1X5.9529Y5.1500Z-0.1251
N1180G1X5.9529Y5.8500Z-0.1251
N1190G1X5.1529Y5.8500Z-0.1251
N1200G1X5.1529Y5.1500Z-0.1251
N1210G00X5.1529Y5.1500Z0.2000
N1220G00X5.9779Y5.1250Z0.2000
N1230G1X5.9779Y5.1250Z-0.1250F30.0
N1240G1X5.9779Y5.8750Z-0.1250F100.0
N1250G1X5.9857Y5.8828Z-0.0815
N1260G1X5.9935Y5.8906Z-0.0645
N1270G1X6.0013Y5.8984Z-0.0521
N1280G1X6.0091Y5.9063Z-0.0423
N1290G1X6.0169Y5.9141Z-0.0342
N1300G1X6.0247Y5.9219Z-0.0274
N1310G1X6.0404Y5.9375Z-0.0167
N1320G1X6.0560Y5.9531Z-0.0091
N1330G1X6.0716Y5.9688Z-0.0040
N1340G1X6.0872Y5.9844Z-0.0010
N1350G1X6.1029Y6.0000Z0.0000
N1360G1X6.0872Y5.9844Z-0.0010
N1370G1X6.0716Y5.9688Z-0.0040
N1380G1X6.0560Y5.9531Z-0.0091
N1390G1X6.0404Y5.9375Z-0.0167
N1400G1X6.0247Y5.9219Z-0.0274
N1410G1X6.0169Y5.9141Z-0.0342
N1420G1X6.0091Y5.9063Z-0.0423
N1430G1X6.0013Y5.8984Z-0.0521
N1440G1X5.9935Y5.8906Z-0.0645
N1450G1X5.9857Y5.8828Z-0.0815
N1460G1X5.9779Y5.8750Z-0.1250
N1470G1X5.1279Y5.8750Z-0.1250
N1480G1X5.1200Y5.8828Z-0.0815
N1490G1X5.1122Y5.8906Z-0.0645
N1500G1X5.1044Y5.8984Z-0.0521
N1510G1X5.0966Y5.9063Z-0.0423
N1520G1X5.0888Y5.9141Z-0.0342
N1530G1X5.0810Y5.9219Z-0.0274
N1540G1X5.0654Y5.9375Z-0.0167
N1550G1X5.0497Y5.9531Z-0.0091
N1560G1X5.0341Y5.9688Z-0.0040
N1570G1X5.0185Y5.9844Z-0.0010
N1580G1X5.0029Y6.0000Z0.0000
N1590G1X5.0185Y5.9844Z-0.0010
N1600G1X5.0341Y5.9688Z-0.0040
N1610G1X5.0497Y5.9531Z-0.0091
N1620G1X5.0654Y5.9375Z-0.0167
N1630G1X5.0810Y5.9219Z-0.0274
N1640G1X5.0888Y5.9141Z-0.0342
N1650G1X5.0966Y5.9063Z-0.0423
N1660G1X5.1044Y5.8984Z-0.0521
N1670G1X5.1122Y5.8906Z-0.0645
N1680G1X5.1200Y5.8828Z-0.0815
N1690G1X5.1279Y5.8750Z-0.1250
N1700G1X5.1279Y5.1250Z-0.1250
N1710G1X5.1200Y5.1172Z-0.0815
N1720G1X5.1122Y5.1094Z-0.0645
N1730G1X5.1044Y5.1016Z-0.0521
N1740G1X5.0966Y5.0938Z-0.0423
N1750G1X5.0888Y5.0859Z-0.0342
N1760G1X5.0810Y5.0781Z-0.0274
N1770G1X5.0654Y5.0625Z-0.0167
N1780G1X5.0497Y5.0469Z-0.0091
N1790G1X5.0341Y5.0313Z-0.0040
N1800G1X5.0185Y5.0156Z-0.0010
N1810G1X5.0029Y5.0000Z0.0000
N1820G1X5.0185Y5.0156Z-0.0010
N1830G1X5.0341Y5.0313Z-0.0040
N1840G1X5.0497Y5.0469Z-0.0091
N1850G1X5.0654Y5.0625Z-0.0167
N1860G1X5.0810Y5.0781Z-0.0274
N1870G1X5.0888Y5.0859Z-0.0342
N1880G1X5.0966Y5.0938Z-0.0423
N1890G1X5.1044Y5.1016Z-0.0521
N1900G1X5.1122Y5.1094Z-0.0645
N1910G1X5.1200Y5.1172Z-0.0815
N1920G1X5.1279Y5.1250Z-0.1250
N1930G1X5.9779Y5.1250Z-0.1250
N1940G1X5.9857Y5.1172Z-0.0815
N1950G1X5.9935Y5.1094Z-0.0645
N1960G1X6.0013Y5.1016Z-0.0521
N1970G1X6.0091Y5.0938Z-0.0423
N1980G1X6.0169Y5.0859Z-0.0342
N1990G1X6.0247Y5.0781Z-0.0274
N2000G1X6.0404Y5.0625Z-0.0167
N2010G1X6.0560Y5.0469Z-0.0091
N2020G1X6.0716Y5.0313Z-0.0040
N2030G1X6.0872Y5.0156Z-0.0010
N2040G1X6.1029Y5.0000Z0.0000
N2050G1X6.0872Y5.0156Z-0.0010
N2060G1X6.0716Y5.0313Z-0.0040
N2070G1X6.0560Y5.0469Z-0.0091
N2080G1X6.0404Y5.0625Z-0.0167
N2090G1X6.0247Y5.0781Z-0.0274
N2100G1X6.0169Y5.0859Z-0.0342
N2110G1X6.0091Y5.0938Z-0.0423
N2120G1X6.0013Y5.1016Z-0.0521
N2130G1X5.9935Y5.1094Z-0.0645
N2140G1X5.9857Y5.1172Z-0.0815
N2150G1X5.9779Y5.1250Z-0.1250
N2160G00X5.9779Y5.1250Z0.2000
N2170G00Z0.8000
N2180G00X0.0000Y0.0000
N2190M09
N2200M30
