Axis Z and X switched
Postby yagodajm » Sun Nov 18, 2018 12:47 am
I started up my cnc today and for some reason the z and x axis where switched. I did make any adjustments to anything. I am running the current version of uccnc, uceth300 board and gecko 540 driver. The day before everything was normal. Any ideas what happened?
Justin
yagodajm
Re: Axis Z and X switched
Postby Demusman » Sun Nov 18, 2018 12:54 am
Did you restart UCCNC and try again?
I have a similar issue where every now and then the machine will home in the opposite direction. Restarting fixes it but it is annoying.
Demusman
Postby cncdrive » Sun Nov 18, 2018 2:10 am
Maybe you loaded the wrong profile?
Postby yagodajm » Sun Nov 18, 2018 3:59 am
Yes, I restarted it a few times. Yes, it is the same profile that I use all the time.
Justin
yagodajm
