Fusion 360 Latest Post File
Re: Fusion 360 Latest Post File
Postby ThreeDJ16 » Fri Aug 31, 2018 5:41 pm
ger21 wrote:
ThreeDJ16 wrote: I was under the impression the program would automatically change that,
UCCNC will not switch, as it only works with the units it's setup in.
If you want to run both metric and imperial code, you need to setup separate profiles for each one.
Yup, I don't plan on repeating this mistake. I did notice that you can change the output when you go to post the file, MM/inch. So I've just got to make sure I keep it in metric, as I prefer working that way. This way our collaboration projects can stay in inch mode (since the other guys prefer that) and I can still post out in metric mode.
Well thanks folks! You helped me solve an issue which drove me nuts last night. I figured it was something simple and dumb I was doing wrong.....typical when I'm up way too late messing with stuff instead of getting the sleep I needed.
ThreeDJ16
Users browsing this forum: Google [Bot] and 3 guests
