2 scripting lanuages ???
Re: 2 scripting lanuages ???
Postby dezsoe » Fri Mar 30, 2018 9:03 am
Vmax549 wrote:So which code is better C# or VB :twisted:
You would have had to be part of the great Mach3 flaming wars to appreciate that remark.
(;-) TP
This question is good. :) It can start war of religions. :) But don't forget: the two languages complie to the same object code, which is .net! In fact, there's no differece at the end, just the input syntax.
Postby dezsoe » Fri Mar 30, 2018 9:28 am
Robertspark wrote:It would be useful to see a semi complex macro (ie a few lines of code) in c# converted to VB so users could see what is involved.
Here are 2 macros with exactly same code. M20910 is in C#, M20912 is in VB. To run these macros you have to home the machine. These macros check the homing precision by rehoming the axes. If you run some stress test g-code and one of these macros, you can check if the homing went away.
M20912.txt
(3.7 KiB) Downloaded 104 times
M20910.txt
(3.49 KiB) Downloaded 107 times
Postby Robertspark » Fri Mar 30, 2018 10:34 am
Thanks Dezsoe :D Just what I was looking for {I thought you'd post something :D :D )
Rob
UCCNC v1.2108 Macro Manual
Users browsing this forum: Bing [Bot] and 7 guests
