Profile
Profile
Postby naijin » Fri Mar 16, 2018 2:05 am
Hi there, I just started using UCCNC with UC100, but I am having a bit of a problem, every time I start UCCNC, it starts with the Default profile, I have to load my own profile and then use the program, I have tried to send the short cut to desk top but to no avail, turn the program off at the end of day, turn it on again and it will start with the default profile again, is there a work around or a setting I may use to start with my own profile instead of the default one? Also is there a list of what each macro does?
Regards
Nick
naijin
Re: Profile
Postby cncdrive » Fri Mar 16, 2018 2:25 am
The UCCNC loads the profile defined in the command line argument of your shortcut.
E.g. the target of the shortcut icon is C:\UCCNC\UCCNC.exe /p yourprofilename
Ofcourse the yourprofilename is the name of your profile and if the profile does not exist then the UCCNC will load the Default profile.
Yes, there is a list of macros. Check the Help/supported m-codes page or the users manual.
Re: Profile
Postby naijin » Fri Mar 16, 2018 5:46 am
Thanks for that, I will set it up in the morning. :D
Nick
naijin
