Tool Table Report
Tool Table Report
Postby Vmax549 » Sat Mar 10, 2018 6:04 am
I guess since we now have a tool table we may need a tool table report 8-)
AND I guess we may need to be able to IMPORT your Cams tool table ??
AND probably need to be able to export the UCCNC tooltable in CSV format ??
(;-)TP
UCCNC Tool Table Report> 3/10/2018 12:58:33 AM
T#, Diam Height Slot Type Mat Desc
Tool>0 0.0000 0.0000
Tool>1 1.0000 1.1000 1 1 a t1
Tool>2 2.0000 1.2000 2 2 b t2
Tool>3 3.0000 1.3000 3 3 c t3
Tool>4 4.0000 1.4000 4 4 d t4
Tool>5 5.0000 1.5000 5 5 e t5
Tool>6 6.0000 1.6000 6 6 f t6
Tool>7 7.0000 1.7000 7 7 g t7
Tool>8 8.0000 1.8000 8 8 h t8
Tool>9 9.0000 1.9000 9 9 i t9
Tool>10 10.0000 1.1000 10 10 j 2 legged catfish
Vmax549
Re: Tool Table Report
Postby Vmax549 » Sat Mar 10, 2018 2:51 pm
Here is a look at the tool table export CSV file.
(;-) TP
1,1.0000,1.1000,1,1,a,t1
2,2.0000,1.2000,2,2,b,t2
3,3.0000,1.3000,3,3,c,t3
4,4.0000,1.4000,4,4,d,t4
5,5.0000,1.5000,5,5,e,t5
6,6.0000,1.6000,6,6,f,t6
7,7.0000,1.7000,7,7,g,t7
8,8.0000,1.8000,8,8,h,t8
9,9.0000,1.9000,9,9,i,t9
10,10.0000,1.1000,10,10,j,2 legged catfish
Vmax549
Postby Vmax549 » Sat Mar 10, 2018 5:48 pm
OK I successfully imported a whole bunch of Frog tools into UCCNC's ToolTable from a CSV file.
I just need to see what formats different CAMs output for a ToolTable export file.
IF you have a CAM that can output a ToolTable export file PLEASE load a copy of yours here so I can see IF I can do a generic import OR if I need to do specific imports for different Cams.
AND tell me what CAM you used to do it.
(;-) TP
Vmax549
Postby Vmax549 » Sun Mar 11, 2018 12:31 am
Another import . This time it was a RhinoCam tool table.
(;-) TP
Vmax549
Postby ger21 » Sun Mar 11, 2018 2:29 am
Fusion 360 Tool Librabry attached.
tools.zip
(33.85 KiB) Downloaded 29 times
Postby Vmax549 » Sun Mar 11, 2018 2:40 am
OK that is the entire tool libray (;-) No way that is going to fit into UCCNC :o
Is there a way in Fusion to export only teh Job or project tools. AND do you have any option as to doing it as a CSV file ??
(;-) TP
Vmax549
Postby alex_s » Sun Mar 11, 2018 8:48 am
you can export as TAB separated
here is an example
42 Tech.zip
(2.49 KiB) Downloaded 31 times
alex_s
Postby Vmax549 » Sun Mar 11, 2018 1:07 pm
Thanks Alex is this the entire tool library or just a JOB summary of tools required.
I find it amazing that NONE of teh programmers of modern CAMs have ever even driven by a machine shop much less understand the need to export a proper tool table.
There is NO WAY all that info is going to be able to be imported into a control :shock: Or for that matter be USED by the controller
All that is required is
Tool#
Tool Diam
Tool Type
Tool Description
Tool Material
At the bare minimum you need
Tool#
ToolDiam
Tool Description
OH Well :roll:
(;-) TP
Vmax549
