Input status conditional run
Postby bdrotaru » Sun Mar 04, 2018 6:20 pm
Hi.
I want to configure software to run as long a input is active (a switch). When this input becomes inactive i want stop button to be pressed.
Cycle start also to depend on this input. If this input is not active, cycle start to display a message.
Can this be done?
bdrotaru
Re: Input status conditional run
Postby dezsoe » Sun Mar 04, 2018 7:26 pm
Yes. You have to set your input as an input trigger to press stop (button 130). (Configuration / I/O trigger / Input trigger) To block start, you have to write a macro to test your input and write a message or start cycle. If the macro is ready, you have to change the screen to start your macro when pressing cycle start.
Postby bdrotaru » Tue Mar 06, 2018 5:14 am
Thank you for reply. Can somebody write this macro?
bdrotaru
Users browsing this forum: Bing [Bot] and 13 guests
