New Ideas for UCCNC features?
Re: New Ideas for UCCNC features?
Postby thegreatwaldo » Sun Dec 04, 2016 9:17 am
Vmax549 wrote:What exactly would you want teh probing plugin to do?
(;-) TP
I think he means something like this http://www.craftycnc.com/probe-it-wizard-mach3/ but working with uccnc. I could do with this as a guitar maker I have to reproduce neck shapes so a probe is about the only way to do this accuarately.
Cheers
Andrew
thegreatwaldo
Postby ger21 » Sun Dec 04, 2016 12:29 pm
I recall that at one point they were working on porting their probing plugin to UCCNC, but haven't heard anything for a while now. You might want to contact them and ask about it.
Postby eabrust » Sun Dec 04, 2016 3:21 pm
ger21 wrote:I recall that at one point they were working on porting their probing plugin to UCCNC, but haven't heard anything for a while now. You might want to contact them and ask about it.
I'm still hoping to make a version of 'ProbeIt', or at minimum the perimeter tracing portion for UCCNC, but currently have not started. 1st problem is my day job has become to much of a distraction currently, so my hobbies have been taking a back seat. 2nd thing is UCCNC will need to support multiple simultaneous axis probing (combined x/y moves in a probe move command). Once that is available, I can hopefully start to work on it (or try to think about it :) ).
Regards,
Eric Brust / CraftyCNC
Postby thegreatwaldo » Sun Dec 04, 2016 5:06 pm
Regards,
Hi Eric
I'll buy it if you ever do it.
Cheers
Andrew
thegreatwaldo
Postby Deon » Wed Dec 07, 2016 10:28 am
Find center of pocket and center of post to start with. maybe if possible a whole part(area). A perimeter inside and out too. Or anything else a probe can do for you maybe?
Deon
Deon
Postby Robertspark » Wed Dec 07, 2016 4:28 pm
If you have Mach3, or not, have a look at Probe-IT [developed by Eric]
You can install it in demo, and there is one for turning centers too
Nice manual too:
http://www.craftycnc.com/help/
The licence is not expensive, and there is little point in trying to re-invent the wheel by developing something yourself unless you're bored and your time is free as Eric did a nice job with that IMHO, nice guy to chat to too as I "metrified" my copy of Probe-It which required shorter DRO's [less digits after the decimal point, and more on the other side + for a bigger table]
+1 for combined axis probing (which seems to be the holdup to anyone developing probing routines other than single axis).
Postby 1JUMPER10 » Sat Feb 04, 2017 8:00 pm
This might be more of a plug in than a feature but it is somewhat similar to multi axis probing.
There is a program for digitizing or, template scanning called "scanything" http://www.sheetcam.com/Scanything/index that works with Mach3. It uses a USB microscope attached to the Z -axis to follow a line and creates G-code of how it moves. I tried it briefly with UCCNC and I was able to get the camera display to open but the rest of it didn't work. I have a couple uses for this type of digitizing if it would work with UCCNC.
Great forum and support here. It's much appreciated.
1JUMPER10
Postby A_Camera » Sun Feb 05, 2017 8:51 am
1JUMPER10 wrote:This might be more of a plug in than a feature but it is somewhat similar to multi axis probing.
Yes, it's a plug in and should not be a built in feature. Also what you describe is a 2D copier. It is easy to just take a picture and convert the pic to G code.
Postby ger21 » Sun Feb 05, 2017 12:35 pm
And if Les is already working on it for both Mach3 and Eding, why not ask him to support UCCNC as well?
Postby 1JUMPER10 » Sun Feb 05, 2017 1:05 pm
I've tried the picture to G-code thing without too much success. Lens effect and scale factors seemed to prevent an accurate duplication of a subject. I guess I'd say it's a 75% solution. If scanything would work it would be exactly what I need.
Gerry - I don't know Les and it seems that any development on the program that he was doing was in 2013?? I get the feeling that he's not working on it any longer. Maybe you could mention supporting UCCNC to him if you think its worthwhile.
1JUMPER10
