ATC - new approach
Re: ATC - new approach
Postby sebba » Sun Jan 05, 2025 10:43 am
I cannot tell you about AXBBE but should work exactly like for UB1
give it a try and let me know if you encounter any issues
- YQWQ
sebba
Postby cncdrive » Mon Jan 06, 2025 5:26 pm
That is how you doing it, just copy the code to the sections for your motion controller using a text editor like notepad.exe.
However some LEDs will be likely not right then especially on the diagnostics screen, because for the example the UC100 has different I/Os then that UC300ETH with the UB1.
Postby sebba » Wed Jan 08, 2025 12:22 am
yes, I did that, and also I tried to keep the original AXBBE lines in place, not to alter the whole config
- YQWQ
sebba
Postby Delco » Sat Feb 15, 2025 12:17 pm
Nice work
Delco
Postby sebba » Sat Feb 15, 2025 2:20 pm
Thank you,
Unfortunately, no time for further developing. CNC activity is very reduced now, so other projects came first.
If someone is interested to continue this work, contributors are welcome!
- YQWQ
sebba
Postby hacker77 » Thu Feb 20, 2025 8:11 pm
HERE IT IS CNCDRIVE AND UCCNC PRETTY MUCH DONE FOR YOU EXCEPT CLEANED UP CODE WISE AND ADDED TO NEW VERSION!!!!
LISTEN TO YOUR CUSTOMERS PLEASE!!!!! :D :D
This Is great UCCNC needs to pick this up from here and RUN with it!!!!!!!!!!
Not everybody can code and this is the perfect Starting point for the new 2.1117 version of UCCNC.
hacker77
Postby hacker77 » Thu Feb 20, 2025 11:33 pm
Daywalker
PLEASE, PLEASE Take this over With UCCNC and finish it up. WE need this exact screen added to the new version.
If I had any idea how to do it I would my brain can only get to the part off using the software. :D :D
hacker77
Postby sebba » Fri Feb 21, 2025 3:31 pm
wow!
hacker, ok, they got it! thanks for credits!
but let's try some small steps before this
even the logic of this macros collection was running on Mach3/MachStdMill for many years without issues, the UCCNC version is kind new and still need a lot of work
as I already said, my CNC activity is very reduced these days, I'm also far away from my router, so very difficult for me to update/finish this implementation.
but - it is always a "but" :D - if will be more persons involved in testing this, I'll do my best to offer support and continue working on it.
so, if possible, try to use this ATC implementation and report back what is OK and especially what is not OK.
feel free to ask about anything, I'll try to reply as soon as possible.
best regards,
Seb
- YQWQ
sebba
Postby Delco » Fri Feb 21, 2025 9:35 pm
If cncdrive wont get on board I am going to try and port it to uc300-eth-5ltp , this is a good start , just need rotary carousel option as well
Delco
Postby sebba » Sat Feb 22, 2025 5:56 am
Great, thanks.
Rotary carousel can be added very easy, just adding one more option for axis orientation and some specific tasks.
Hope I'm not wrong, I didn't got my morning coffee
- YQWQ
sebba
