JOG Pendant
Re: JOG Pendant
Postby RWC » Thu Mar 28, 2019 5:44 pm
OK great !
thanks for that clarification.
The macros were put in yesterday and are ready to go.
Soon as I get this wiring changed and connected.
Thanks so much,
Russ
RWC
Re: JOG Pendant
Postby Juka » Sun Mar 31, 2019 9:20 pm
I would also like to use wired MPG on my machine and I will need at least 8 inputs to connect this handwheel to BOB.
I already bought AXBB-E controller and extra BOB, but I think inputs will not enought. Can someone give some recommendations how to get more inputs?
(A, B/X, Y, Z/x1, x10, x100)
Juka
Re: JOG Pendant
Postby RWC » Tue Apr 02, 2019 8:56 pm
Hi Juka,
I need the same as you.
I think there are only 11 inputs available using the AXBB. 6 on port 2, and 5 on port 3.
Will watch for other suggestions (hopefully OTHER than going to another controller board) :?
Russ
RWC
Re: JOG Pendant
Postby ger21 » Tue Apr 02, 2019 10:41 pm
How about an Arduino using Modbus?
Re: JOG Pendant
Postby RWC » Mon Apr 08, 2019 1:28 pm
Hi Gerry. Are you familiar with the Arduino ?
Which product would you recommend ?
RWC
Re: JOG Pendant
Postby Vmax549 » Mon Apr 08, 2019 1:39 pm
Hi Russ, IF you are not using teh analog inputs you can use them to run teh 2 rotary switches. You would set teh switches up as a string of resistors and measure teh voltage at each selection. The create a macroLoop to use teh values to make selections.
Just a thought, (;-) TP
Vmax549
Re: JOG Pendant
Postby RWC » Mon Apr 08, 2019 1:43 pm
That is a cool approach ! :)
I might just try that, will need help with the details, of course.
Thanks for the suggestion TP,
Russ
RWC
Re: JOG Pendant
Postby ger21 » Mon Apr 08, 2019 2:10 pm
RWC wrote:Hi Gerry. Are you familiar with the Arduino ?
No, never used one.
Re: JOG Pendant
Postby Juka » Mon Apr 08, 2019 7:17 pm
Modbus sounds Good. Is there any plug and play solution, pcb with terminals? I am now familiar with modbus yet.
Juka
Re: JOG Pendant
Postby dezsoe » Mon Apr 08, 2019 8:40 pm
There are many working open source solutions for Arduino Modbus, both serial and Ethernet.
