1.2104 stops at M1 only first time thru subroutine loop
Postby dammogreen » Sun Apr 15, 2018 2:54 am
V 1.2104 (and also 1.2103)
I have an M1 stop placed within a looping subroutine, the programs only stops at the M1 on the initial (first) time it loops through the subroutine.
On the 2nd and 3rd loop/pass it never stops at the M1.
(-----RUNNING PROGRAM-----------------------------------------------------)
#900=0 (you can MDI to set this value also)
(G92.1 (cancel temp offset))
M20001 (close collet)
G20 (inch units)
G0 (RAPID)
M20004 (display loop count)
G54 (DCMT070204)
G1 F 60
M98 P100 L3 (call subroutine 100, 3 times M99 is return from sub)
M30
o100 (the subroutine)
Z2
M1 (test, !!! only stops here on first time through...not every time??? <<<<-------------------------------------------)
X1
Y2
Z3 X2 Y3
#900=[#900 +1]
M99 (return from sub)
dammogreen
Re: 1.2104 stops at M1 only first time thru subroutine loop
Postby dammogreen » Mon Apr 16, 2018 3:04 am
As a temporary kludge, I wrote a macro to use instead of M1 when inside of loops, that is controlled by the standard OPTIONAL M1 stop function.
I discovered a more pressing issue that I posted in the bug forum, that involves improper code restart point after a loop return.... viewtopic.php?f=3&t=1190
dammogreen
Postby Vmax549 » Mon Apr 16, 2018 1:28 pm
I can confirm that teh M1 does not work after teh first call in a subroutine.
(;-) TP
Vmax549
