ATC Project - Planning Advice Request
Re: ATC Project - Planning Advice Request
Postby lp_felix » Fri May 22, 2020 4:18 pm
Problem solved, I turned off soft limits on macro as turned back on when macro finish.
Now, how can you made uccnc remember last used?
I can't understand why uccnc don't store tool number between sessions.. :(
lp_felix
Postby dezsoe » Fri May 22, 2020 5:50 pm
Save the tool number just after you change it in the M6 macro:
    exec.Setcurrenttool(NewTool);
    exec.Writekey("LastTool", "ToolNumber", NewTool.ToString());
Save the following macro and start it as a macroloop:
// Restore last tool number on startup
bool ResetNow = exec.GetLED(ResetLED);
if (FirstRun && !ResetNow)
  while (!exec.GetLED(ResetLED))
    Thread.Sleep(10);
FirstRun = false;
if (NeedCheck && !ResetNow)
  Thread.Sleep(100);
  exec.Codesync("");
  if (!exec.Ismacrostopped())
    string LTstr = exec.Readkey("LastTool", "ToolNumber", "0");
    int LastTool = Convert.ToInt32(LTstr);
    exec.Setcurrenttool(LastTool);
    // Uncomment the next 3 lines to turn on tool length offset for the loaded tool
    // exec.Wait(100);
    // int Currenttool = exec.Getcurrenttool();
    // exec.Code("G43 H" + Currenttool.ToString());
    exec.AddStatusmessage("Tool number T" + LastTool.ToString() + " restored.");
    NeedCheck = false;
    loop = false;
  else
    exec.AddStatusmessage("Waiting stop to clear...");
    Thread.Sleep(1000);
#Events
const int ResetLED = 25;
static bool FirstRun = true;
static bool NeedCheck = true;
Postby lp_felix » Fri May 22, 2020 8:08 pm
PERFECT!!!!
tested and work perfectly
Super tanks @dezsoe
;) :D :D
lp_felix
