UB1 Breakout Board - how to connect the periphery
Postby Maddin » Fri Dec 08, 2017 4:47 pm
Hello everybody,
I recently bought the UB1 and I'm currently busy with the wiring.
I have a Z-axis with a brake: how do I connect it (my old TripleBeast has a separate connector for this)? :(
Regrads,
Martin
Maddin
Re: UB1 Breakout Board - how to connect the periphery
Postby Maddin » Mon Dec 11, 2017 8:04 am
No one, who has the same Problem?
Maddin
Postby Robertspark » Mon Dec 11, 2017 10:36 am
What do you use the brake for?
The only brakes I've seen (and my experiance is limited) are for those stepper motors that could drop when power is not applied to the drive
https://www.omc-stepperonline.com/image ... 0x1000.jpg
http://spanish.jingbomotor.com/photo/pl ... _brake.jpg
used with something like this type of arrangement:
https://www.youtube.com/watch?v=CZjPkw5ptmk
I would wire it fail safe via the enable pin, so that when the drive is active, the relay drops the power supply out to the brake, and when the power drops out, the e-stop is active the relay disengages and power is restored to the brake.
{i.e. wire via a normally closed relay}
You may need to provide some photos or a bit of a better description if this is not what you're looking for.
Postby cncdrive » Mon Dec 11, 2017 11:12 am
If the brake is to hold the axis when the power goes off, so e.g. the Z-axis will not roll off to the table then you could connect it e.g. on a relay on an enable output from the UCCNC or on the charge pump signal,
so the brake releases when the UCCNC runs or when is not in reset, depending on if you will use an enable or charge pump and how you configuring it.
Postby Derek » Mon Dec 11, 2017 10:17 pm
cncdrive wrote:If the brake is to hold the axis when the power goes off, so e.g. the Z-axis will not roll off to the table then you could connect it e.g. on a relay on an enable output from the UCCNC or on the charge pump signal,
That's how I have my Z axis on my mill. works perfectly.
Derek
Postby Maddin » Wed Dec 13, 2017 5:12 pm
Yes, my brake is to hold the Z-axis when the power goes off: http://spanish.jingbomotor.com/photo/pl12694885-nema_23_nema_34_nema_42_stepper_motor_with_brake.jpg!
I think this is the solution for my problem (a relay on an enable output from the UCCNC or on the charge pump). I will follow your advice, thanks a lot! :)
Maddin
