VFD parameters
VFD parameters
Postby Coyote94 » Tue Sep 10, 2024 9:03 pm
I use en FVD Folinn BD600 for my 24000tr spindle, I try to use it I get some bizarre symptoms :
- if I enter S5000 M3 command, then spingle goes to full speed (24000trs) and VFD shows 800 (for 800hz)
- when I move speed cursor to 0% then speed down and VFD shows 792
- sometime when I click on "CW" button, spindle doesn't move and VFD shows 50
Hereby my UCCNC config
and VFD config
I'm pretty certain is bout some parameter in UCCNC but which ones ?
Coyote94
Re: VFD parameters
Postby cncdrive » Wed Sep 11, 2024 5:06 pm
I would measure the analog output voltage from your motion controller to figure if it is UCCNC or VFD problem.
Re: VFD parameters
Postby Coyote94 » Wed Sep 11, 2024 5:42 pm
it's fixed !
I had installed several UCCNC instances on the PC (test, Prod, versions) to do tests.
Several times, I had error messages about sharing libraries which crashed the application.
I focused on the 2 main versions that I was using; one with a black screen and one original.
By measuring the voltage on the black version, I only had 10v or 0 but also weird things when launching the spindle with a button: it worked then not, it went through with the command then nothing or it crashed.
Same exercise with the original version and there the measurements change according to the speed.
Conclusion: application developed with the left elbow because everything is dependent; interface, settings, commands and the libraries but not surprising on Windows.
Coyote94
