Hello! I have a question...I know that the UC goes at 5v and the HDBB2 at 12v, so based on this, which is better? power the UC via USB and the HDBB2 with another source? or all with the same 12v source and a 5v regulator?
I ask this because I have problems with the UC300-usb when I connect it to the PC and then turn on the power of the HDBB2 the UC disconnects and I have to disconnect it from USB, connect it again and restart mach3 (which also gives me some problems losing the connection with the UC300 randomly...)
What do you think about the software power problem? Thank you so much!
