UC300 5V Analog output voltage
Postby Delco » Mon Oct 30, 2023 1:33 am
On the UC300 is there any mechanical way to limit the analogue output voltage to 5V max like on the AXBB-e
or is the only option to limit the PWM max duty to 50% and set the max spindle velocity to double the required max speed?
So if my actual max spindle speed at 5V is 3000rpm , I would set the max velocity to 6000rpm and the PWM max to 50%
Delco
Re: UC300 5V Analog output voltage
Postby dezsoe » Mon Oct 30, 2023 7:08 am
No, but you can build a voltage divider using two resistors or a potentiometer.
Postby ger21 » Mon Oct 30, 2023 12:42 pm
Why do you have to set the velocity to double?
I had a VFD set to 0-5V, and just set the PWM to 50%, with the correct RPM, and it worked fine.
Postby Delco » Tue Oct 31, 2023 7:42 am
ger21 wrote:Why do you have to set the velocity to double?
I assumed to calibrate the rpm , 100% PWM is max spindle rpm ?
Delco
Postby ger21 » Tue Oct 31, 2023 10:38 am
No, I believe the PWM duty corresponds to the spindle velocity.
Max PWM is the output at max spindle velocity.
If you set max velocity to 3000, and max pwm to 50%, you'll get 5v at 3000 rpm.
