I'm trying to use AXBB-E with CL57T drivers but despite wiring check, re-check any stepper motor move.
Regarding the whole wiring, I respected CNCDrive schema X PUL+ -> O9 etc..
Regarding driver wiring, I resigned this table to identify cables/ports
In UCCNC, the port indicators light up but only in negative values, nothing lights up in positive values.
Indicators stay on if I only press "-", as soon as I press "+" the port indicators go off.
Hereby my UCCNC config :
Leads/diagnosis carried out:
- Checking wire colors according to the table above
- Test with new 1m cable, I have 3m, on motor X
- 5VO connected to common 5V transformer then to 5V0 Port1. on board
- Disconnect all limit/homing/BAU from the board
- Change Kernel Frequency from 100 to 200kHz
- Disable all limit/homing/BAU in config
- Inverted A/B signal
Many thanks in advance for any help
