by cncdrive » Fri Oct 06, 2023 10:14 am
Yes, you can use the 5V0 and output pin of the UCSB.
The UCSB has high speed isolated outputs using 10Mbit/sec opto-isolators, so it should work fine with your laser and it can also output step/dir signals without problem.
