HY VFD connection to uc300eth + UCBB
Good morning every one
I wanted to ask for help as I already done some upgrades on my machine with X and Z axis and I had g-penny 2.2 KW spindle with Huan Yang VFD laying around so I decided to switch from my 1.5KW + sunfar C300 to HY VFD +2.2KW and here is my question
how to connect hy vfd to uc300eth + UCBB
here on HY VFD there are two lines of terminal 1 and 2 which ACM should I use form 1 or from 2 ?
is this correct connection ?
uc300eth + UCBB
analog port UCBB pin 5 ground ------> HY VFD ACM ( terminal 2 or terminal 1 ? )
analog port UCBB pin 6 analog output 0 ------> HY VFD VI ( terminal 2 ? )
uc300eth CN2 output O17 ------> HY VFD FOR ( terminal 1 from photo )
HY VFD setting that i hanged to be able to control speed :
JP1 pin set to VI
PD001 set to 1
PD002 set to 1
PD070 set to 0
is there any thing that I miss out here in vfd configuration and wiring it to uc300eth + UCBB ?
Few days ago I send email to UCCNC support but still didnt get any answer from them again
uc300eth + UCBB
JP1 pin set to VI
PD001 set to 1
PD002 set to 1
PD070 set to 0
